Is there a mod to add a door lock switch to the inside of the rear hatch?
Old Oct 1, 2011 | 07:18 PM
tfrost's Avatar
tfrost
Question Is there a mod to add a door lock switch to the inside of the rear hatch?
I would like to lock and unlock the rear hatch from the inside of the rear hatch without having to always use the key. I don't have power door locks.
Old Oct 2, 2011 | 12:08 AM
master tech's Avatar
master tech
Site Moderator & Tech
I'm sure you can, as long as you have a fused power and ground.
Old Oct 2, 2011 | 06:56 PM
tfrost's Avatar
tfrost
Not powered, just a manual switch on the inside of the hatch.
Old Oct 3, 2011 | 04:07 PM
Black3SR's Avatar
Black3SR
Why not take the inside panel off to see what lever(whatever) releases the catch. Then fasten a piece of wire(coat hanger) to it and bring it out through a small hole you make in the panel. Then you would just pull on the wire to release.
