03 Caravan 1 front 1 rear brakes
03 Caravan SE with ABS brakes, disc up front drums in the rear. For a couple of days I noticed the brake pedal getting softer and softer and the brakes getting worse with the pedal going almost to the floor. At this point I only had front right and rear left brakes working.
I have gone over all the lines for a leak and a mechanic friend also looked
over the lines but no leaks found. I bled the system 4 times and could not get rid of the air in these two lines. I talked to a couple of mechanics and they thought that it was my master cylinder. So I replaced the master cylinder and bled the whole system again. It felt like I had good pressure until I started the van and then the pedal was almost to the floor again with only the front right and rear left brakes working as before.
Now I am being told it might be the ABS control!
Anyone have an idea as to what has happened to my brakes?
