2009 Grand Caravan Bolt Pattern
Old Oct 18, 2011 | 11:59 AM
smelanson's Avatar
smelanson
Question 2009 Grand Caravan Bolt Pattern
I have been having trouble finding used steel winter rims for my 2009 Grand Caravan due to the bolt pattern. Is the bolt pattern for the 2008-2011 Grand Caravan 5 x 127? What other cars\trucks use this size? The older Caravans appear to use 5 x 114.
Old Oct 31, 2011 | 10:15 AM
vpnavy's Avatar
vpnavy
Until someone pipes in - I found the following (don't know how reliable it is)...
MODEL: GRAND CARAVAN, CARAVAN LE
YEAR: 87-on
BOLT PATTERN: 5X114.3
LUG SIZE: 12mmX1.5
CENTER BORE: 71.5
Old Oct 20, 2012 | 03:49 PM
Dobs's Avatar
Dobs
5x127mm (5x5") for 2009
Old Feb 14, 2013 | 02:49 PM
E.Giovanni's Avatar
E.Giovanni
Default Rim size, 2008-2013 Grand Caravan.
Found a couple of links to wheel suppliers which answers the questions for the Grand Caravan. http://www.streetdreams.org/rims/dod...-caravan-rims/
Looks like Dodge changed the rim in the 2008 model year and carried through to current 2013. Rim is 16" x 6.5", Bolt pattern is 5 x 127mm, centre bore is 71.5mm, offset is 34-45mm. Costco has a look up for steel wheels. http://www.costco.ca/Steel-Wheels,-H...100018256.html Click on the link beside the pic of the rim to download a pdf guide. It shows the correct hub-centric rim as model X45521. Page 62 of the guide shows other vehicles that use this same wheel. I feel better knowing two or more suppliers agree especially if shopping on Kijiji or Craigslist. Hope this helps.
Old Apr 29, 2013 | 10:34 AM
schifty2's Avatar
schifty2
I'm trying to upgrade wheels on my 2008 Caravan. The "high offset" requirement means that Jeep wheels won't fit - the calipers on the Caravan interfere. I'm new to this forum, and came here looking for info for any other Dodge vehicles that have wheels that will work for me.
Let me know if you've found any leads.
