Neutral/backup saftey switch- 2001 caravan
Old Oct 31, 2011 | 08:03 PM
Hayburner's Avatar
Hayburner
Default Neutral/backup saftey switch- 2001 caravan
Where is the neutral/backup saftey swith on a 2001 Dodge Caravan. Thanks in advance for any help.
Old Nov 1, 2011 | 12:01 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The back up and neutral switch is part of the TRS. ( Transmisson Range Switch ) There should be two connectors under the battery. Make sure the connection are good first before replacing the TRS.
Old Nov 1, 2011 | 01:19 AM
Cougar41's Avatar
Cougar41
...and the TRS is inside the transmission above the valve body.
