2001 dodge grand caravan PROBLEMS
Old Nov 4, 2011 | 07:10 PM
dddon's Avatar
dddon
Unhappy 2001 dodge grand caravan PROBLEMS
when i switch on the headlights , only the left or right side lights up, and when i use the dimmer switch , the opposite side headlight lights up and the first one goes out ????? both clearance lights burn brightly ... so not a ground problem and i checked the headlight bulbs, both are good on both filaments .... ??
also .... the windshield washer does not squirt fluid ...wipers run fine ?? ???
i guess i need wiring diagrams that could have wire colors or pin numbers on the junction blocks??? i need a beer too!!
dddon
Old Nov 4, 2011 | 11:54 PM
vpnavy's Avatar
vpnavy
Did both (lights and wiper) problem start at the same time? Windshield washer - are we talking about the front or back? Have someone hit the washer button while you stick your head under the hood - do you hear the washer motor running? If you do, check your hoses for cracks, clogs, etc.
Old Nov 5, 2011 | 10:02 AM
dddon's Avatar
dddon
yes .... all problems began about the same time .... neither washer motor runs ... can someone help me locate a wiring diagram that shows the wiring from the control unit to the lights and washer motors ?// dddon
Old Nov 5, 2011 | 10:41 AM
greaper_ca's Avatar
greaper_ca
Check this link for service manuals for the Caravan. I'm having the same problem with my washer.
http://oskin.ru/pub/chrysler-dodge/m...ravan_Voyager/
Old Nov 5, 2011 | 02:14 PM
jumpdrive2's Avatar
jumpdrive2
check connection c5 on bcm looks like both headlight and washer run thru it also check front control module as it is know to have connection problems
here are the diagrams you requested good luck
Old Nov 5, 2011 | 02:26 PM
jumpdrive2's Avatar
jumpdrive2
Old Nov 5, 2011 | 02:27 PM
gentz's Avatar
gentz
usually indicates a bad integrated (intelligent) power module....seen many of these...
Old Nov 5, 2011 | 02:55 PM
Cougar41's Avatar
Cougar41
The IPM or the attached FCM? As I understand it the FCM is what splits the single input (PCI data base from BCM) to the IPM into 4 outputs to each corresponding headlight filament.
Old Nov 5, 2011 | 03:12 PM
Cougar41's Avatar
Cougar41
Deleted duplicate post
Old Nov 5, 2011 | 03:13 PM
Cougar41's Avatar
Cougar41
dddon
A fair number of folks on several forums have reported some success fixing your identical headlight problem by either cleaning corrosion or slightly bending the contacts at the FCM to IPM connection. Disconnect the negative battery cable then remove 4 bolts securing the FCM to the IPM (fuse box). Just pull the FCM off. The wide spade contacts #3,4,5,6 are for the headlights.
