Caravan door stuck
Old Nov 8, 2011 | 06:21 PM
Scamilleri1228's Avatar
Scamilleri1228
Default Caravan door stuck
I have an 03 caravan with the pass rear door stuck. The actuator gets power, but the linkage will not move. The door is closed right now so I can't loosen the fasteners that hold the latch in place. Any ideas?
Old Nov 8, 2011 | 06:46 PM
Cougar41's Avatar
Cougar41
Remove the inner trim panel, manipulate the lock mechanism inside the door, open door. Then you'll have to fix whatever needs fixin.
