Rear hatch struts
Old Nov 30, 2011 | 10:55 PM
lroland's Avatar
lroland
Default Rear hatch struts
I have a 2004 Grand Caravan. Do the struts on the rear hatch fail and can they be replaced. In cold weather the hatch will not stay up without holding it.
Old Dec 1, 2011 | 12:33 AM
papaduck's Avatar
papaduck
Yes, the struts do fail. Not hard to replace. Most parts stores can get the replacements if they do not have them in stock. Ebay lists them, just make sure you get the right length, connectors and the lifting power.
Old Dec 1, 2011 | 04:32 PM
wilcom's Avatar
wilcom
I just replaced the struts on the hatch on my 95 Caravan, just takes a torx socket and a post to prop up the tail hatch while changing them.
I went to the junk yard and found a set that had good action for $12 for the pair. My local parts place wants close to $50 for a pair of air struts. I put the extra $38 in the fuel tank.
Joe
Riverside, Ca
Old Dec 1, 2011 | 06:55 PM
mfahey's Avatar
mfahey
If you can get someone to hold the hatch up, it makes things a whole lot simpler. There is only a very limited range of motion to get the hatch bolt started so getting something to hold it in exactly the right place can be a challenge and you definitely don't want the hatch coming down on you.
Old Dec 3, 2011 | 01:47 PM
mrHermit's Avatar
mrHermit
I remember years ago receiving a recall notice for the rear door struts on my 93 Dodge grand Caravan. I took the notice and the van to the dealer and they replaced them at no charge. I don't know what model years this recall affected or even if it's still in effect today, but you might want to check with your dealer before you replace them yourself.
Old Dec 10, 2011 | 01:20 PM
lroland's Avatar
lroland
Thanks for the advice, I changed them out, about $23 each, works great now.
