Won't shift out of first. P0750
Old Dec 1, 2011 | 04:05 PM
ChiTownMatt's Avatar
ChiTownMatt
Default Won't shift out of first. P0750
Hello this is my first post.
I have a 96 grand caravan 3.3L. The engine shift hard into reverse and drive, and won't shift while driving. The RPM's just go up as the speed increases, so if I drive at 40MPH the RPMs are above 3,000. I had a code read and it came up P0750.
Shift solenoid "I" performance
Vehicle at cruise then the ECM detected the actual gear did not match the commanded gear.
Any help would be appreciated. If more info is needed please let me know. Thanks.
Old Dec 3, 2011 | 11:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Your transmission has gone into limp in mode. The problem could be a solenoid pack, wiring or a problem inside the transmission. I do have PDF files if you need them.
