a/c does not work
Old Dec 27, 2011 | 12:00 PM
plunges25's Avatar
plunges25
Default a/c does not work
a couple of months ago the a/c in my dodge grand caravan stopped working. when i check it out there was smoke comming from the compressor. i have checked to see if there is still freeon in the systmem and there is. i dont think its the compressor because there is still freeon in the system. any ideas would be helpful.
Old Dec 27, 2011 | 12:38 PM
TurboStixx's Avatar
TurboStixx
Compressor can have freon but not be working properly.
Old Dec 27, 2011 | 12:43 PM
plunges25's Avatar
plunges25
when i looked at it over the weekend it looks like the clutch is seperating from the compressor. i can what looks like a bearing but i am not sure.
Old Dec 27, 2011 | 02:31 PM
Tizzy1's Avatar
Tizzy1
I am going to assume the model year is somewhere between 2001 - 2003 ish. Very common, so much in fact that the compressor warrenty was extended to 7/70, which I am sure you are over. The compressor would fail internally from lack of oil and the clutch would melt down. There were updated suction and discharge lines, a drier/filter and a compressor sold in a kit for that problem. If the compressor grenaded bad enough, you had to replace the h-valves as well.
Old Dec 27, 2011 | 10:03 PM
TurboStixx's Avatar
TurboStixx
Take a picture and post it for us. We might be able to tell you a little more with a picture.
Old Jan 2, 2012 | 12:47 PM
plunges25's Avatar
plunges25
thanks for the help. i took off the clutch assembly and founf the pulley bearing was toasted. i have replaced it and the a/c is working great.
