Pcm?
Old Dec 28, 2011 | 11:09 AM
malaybog's Avatar
malaybog
Question Pcm?
I'm new to this site, on Christmas eve my 2003 Caravan stalled and would no longer start, you can hear the starter relay doing it's job but still won't start. The battery checked out good I took the starter out and tested out good as well and, checked continuity between starter relay pin 85 to PCM pin 31 good there checked pin 87 from starter relay to yellow and grey starter wire good there too. But no 12 volts on yellow and grey starter wire when ignition key is turned. Does this mean my PCM is bad, I just want to make sure I diagnosed this correctly any help would be appreciated.
Old Dec 28, 2011 | 02:31 PM
vpnavy's Avatar
vpnavy
Welcome Aboard malaybog! Stay tuned - a Technician (or member) will jump in shortly to provide a possible solution. In the meantime, don't forget to browse Sub-Forums: Caravan for stuff related to your ride.
Old Dec 29, 2011 | 11:09 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I'm going to move your post to the minivan section. This way you will get some answer to your questions.
