'98 Caravan 3.0 / Doing Repair...what else to replace?
Old Jan 2, 2012 | 03:08 PM
tbeck1985's Avatar
tbeck1985
Default '98 Caravan 3.3 / Doing Repair...what else to replace?
Removing the timing chain cover because it is leaking oil severely...what else should i replace?
So far:
new coolant and distilled water
new oil and filter
water pump and hoses
timing chain cover gasket
timing chain
oil pan gasket
o-rings
crank seal
what else would you all replace?
Old Jan 2, 2012 | 03:15 PM
Tizzy1's Avatar
Tizzy1
a 3.0L has a timing belt. Replace the belt and tensioner
Old Jan 2, 2012 | 04:27 PM
tbeck1985's Avatar
tbeck1985
it was my mistake, it's the 3.3...should have double checked. i just got it from my brother in law and was going by what he said
also, apparently the oil pan is coming down so add oil pan gasket
what about a new crankshaft oil seal?
Old Jan 2, 2012 | 07:54 PM
mrtinker's Avatar
mrtinker
How about some pictures of the work? Before & After's???
Old Jan 2, 2012 | 08:12 PM
tbeck1985's Avatar
tbeck1985
Yea, I can do that. So far I've got the motor mount out, the ac moved, coolant and oil drained, obviously the belts off and the crank damper is off. Getting ready to remove the idler pulley, the engine bracket and then the timing chain cover.
Got a severe headache after straining to get the bolt out of the damper...so I took a break. My butterfly impact wouldn't even break it.
Old Jan 3, 2012 | 11:16 AM
Tizzy1's Avatar
Tizzy1
There are 3 orings on the rear of the cover that you will want to replace and yes the crank seal. Make sure the crank is not grooved by the seal.
Old Jan 3, 2012 | 11:52 AM
tbeck1985's Avatar
tbeck1985
the o-rings weren't even circles anymore, the gasket was all but non-existant. i'll check the crank for sure. also, the timing chain was decently tight on one side and loose as hell on the other...gonna replace that too.
