radio wiring diagram and removal for a 2010
Old Jan 3, 2012 | 09:11 AM
dmhassay's Avatar
dmhassay
Default radio wiring diagram and removal for a 2010
i have the 6 speaker system with steering wheel controls. there is a wiring harness sold for around 120$ that I really dont want to purchase. does anyone have the wiring diagram for the factory radio? mine has no cd changer, not touch screen, no sub, has 6 speakers. for a new radio I simply need constant and switched 12 volt. i will add my own amps and speakers. I dont mind losing the steering wheel controls or the sirius/xm. i dont mind cutting a wire or two from the factory harness as long as radio removal doesnt cause any other problem. also, what is the radio removal process? I have searched and searched and just cant find the info.
Old Jan 3, 2012 | 09:16 AM
TurboStixx's Avatar
TurboStixx
To get this diagram I need the information on your car, Year make model engine size ( I know it is a Dodge Caravan)
Edit: Sorry, I didn't read the entire Title Line.
Old Jan 3, 2012 | 09:55 AM
dmhassay's Avatar
dmhassay
thanks for the quick reply. 2010 grand caravan. six cyl. not sure about cu.in. can check during lunch if needed.
Old Jan 3, 2012 | 10:56 AM
TurboStixx's Avatar
TurboStixx
Don't need it, give me a few and I will try to get that wiring diagram for the stereo for you
Old Jan 3, 2012 | 11:03 AM
TurboStixx's Avatar
TurboStixx
The actual diagram has not been made as of yet (heck chilton manual didn't even have Dodge listed under 2010!) But, this is the wiring colors and what they go to, if you need more than this, I might be able to dig something up.
2010 Dodge Grand Caravan Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Yellow/Red
Car Radio Accessory Switched 12v+ Wire: N/A
Car Radio Ground Wire: Gray/Violet
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Gray/Violet
Left Front Speaker Negative Wire (-): Gray/Yellow
Right Front Speaker Positive Wire (+): Dark Green/Violet
Right Front Speaker Negative Wire (-): Dark Green/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Green
Left Rear Speaker Negative Wire (-): Gray/Dark Green
Right Rear Speaker Positive Wire (+): Dark Green/Light Green
Right Rear Speaker Negative Wire (-): Dark Green/Gray
Old Jan 3, 2012 | 11:13 AM
TurboStixx's Avatar
TurboStixx
On Radio removal, I am not 100% I have a 01 :-( But like to help you guys out, That is the 2010 Wire coloring for the stereo
Old Jan 3, 2012 | 12:43 PM
dmhassay's Avatar
dmhassay
thanks so much. once i get the radio removed I will post the removal info.
Old Jan 3, 2012 | 02:41 PM
TurboStixx's Avatar
TurboStixx
Not a problem, looking forward to how to remove the radio
