Brakes
Old Jan 2, 2012 | 03:21 PM
Carl Wills's Avatar
Carl Wills
Default Brakes
I just replaced the front and rear brake pad approximately 3mths ago and now have a squeek in the rear. The brake light has started going on and off. there is a whistling noise from the rearend when I am backing up. This thing is going to hell in a hand basket! The passanger sliding door has also started to rattle. Any help would be GREATLY Appreciated!
Old Jan 2, 2012 | 03:31 PM
Tizzy1's Avatar
Tizzy1
Welcome to the forum. What year is your van? For the brake lamp, make sure the master cylinder is full. Pads have a tendency to squeek if you are a light braker.
Old Jan 5, 2012 | 11:15 PM
Carl Wills's Avatar
Carl Wills
Default Brakes
The van is a 2009 and I checked the fluid and added about half a bottle. The light is now off but am still concerned because I don't see any leakage on driveway. Thanks for any advice.
Old Jan 6, 2012 | 11:55 AM
Tizzy1's Avatar
Tizzy1
Check the rear calipers for a possible leak. There is a technical service bulletin for the sliding door rattle but I can't cut and paste it here. I can probably email it to you if you would like. Send me a private message with your email and I will see what I can do.
