My 1999 Dodge Grand Caravan heater fan isn't working
Old Jan 10, 2012 | 04:19 PM
kimberly65's Avatar
kimberly65
Unhappy My 1999 Dodge Grand Caravan heater fan isn't working
Hello !
My name is Kimberly and I need some help diagnosing an intermittent problem with my Grand Caravan heater fan. It is a 1999 and my heater fan would work and then stop but would be working again after my vehicle sat overnight. For the past 3 days it has not worked though and it is getting colder. Can you help me determine where to start looking for the problem?
Thank you very much!
Old Jan 10, 2012 | 04:27 PM
vpnavy's Avatar
vpnavy
Welcome Aboard kimberly65! Stay tuned - a Technician (or member) will jump in shortly to provide a possible solution. In the meantime, don't forget to browse Sub-Forums: Caravan for stuff related to your ride.
Old Oct 2, 2012 | 09:07 PM
1st caravan's Avatar
1st caravan
I too am having the same problem. I was told that it was a bad switch. I am going to replace it and see what happens
Old Oct 2, 2012 | 10:59 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
For both of our new members, I would guess the fan blower relay maybe the problem. You would need to remove the wiper cowl to replace it. I will move your post to the Minivan section/ Caravan.
Old Oct 3, 2012 | 02:53 AM
Cougar41's Avatar
Cougar41
Originally Posted by master tech
Welcome to DF
Wiring diagrams are showing the front blower motor relay in the PDC. Has something changed?
Old Oct 4, 2012 | 10:39 AM
1st caravan
Default heater fan fixed
I went ahead and replaced the relay and it worked. My heater fan works again. I also went ahead and replaced the blower fan fuse and relay and it all works. Thank you very much for the help.
