Can someone here recognize this "strange nut"?
Old Jan 14, 2012 | 10:54 AM
mrtinker's Avatar
mrtinker
Default Can someone here recognize this "strange nut"?
I encountered this on the motor mount (passenger side above the wheel well) and had a hell of a time getting it loose without damaging it...
Thanks in advance!
Old Jan 14, 2012 | 12:43 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
never seen that before but it might be special case, is it reverse screwed on? or just different being what it is?
Old Jan 14, 2012 | 02:58 PM
trophyslayer's Avatar
trophyslayer
I havn't seen them before on cars, but I think they are a Pentahead bolts and need a Penta Socket
not sure what size you need
http://www.amazon.com/SEPTLS8759076-.../dp/B00279LD62
Old Jan 14, 2012 | 09:55 PM
steak59's Avatar
steak59
never seen a pentagon nut before on cars, Not ever German cars.
Old Jan 14, 2012 | 11:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
That is the pentastar nut and you don't remove it. It part of the motor mount and you replace the whole mount. If you do need to remove the nut, you may need either a 18mm or 20mm open end wrench.
Old Jan 15, 2012 | 12:26 PM
mrtinker's Avatar
mrtinker
Its a right-tighty thread. I don't remember if I "had to" remove it or not but I do know I had to block the engine from falling before removing it. I was thinking that was the reason Dodge put it there...letting us diy'ers know its a pretty important fastener.
Anyway, haven't searched yet for the proper "pentastar" wrench but can anyone tell me where to get it?
And for reference, no standard or metric socket or open end wrench would fit on this.
Old Apr 12, 2012 | 03:38 AM
no_way_ray's Avatar
no_way_ray
Default Pentastar nut?
I came across this nut today while changing a friend's timing belt on a 2000 2.4 Caravan. I removed the entire bracket and it wasn't until I needed to remove the nut (to replace the torn mount) that I realized that it was 5-sided. A fire hydrant wrench works great to remove it (I tend to do a lot of auto work while on-duty at my station). I purchased a M12x1.75 (maybe it was 1.5) nut from NAPA to replace the 5-sided unit. In my opinion, an interfering thread nut would have been a better choice than this odd-ball nut. My $0.02
