Safety Switch Neutral
Old Jan 23, 2012 | 12:40 PM
Bugworks's Avatar
Bugworks
Default Safety Switch Neutral
Hello together
I'm new here and need some help please.
2003 Dodge Caravan
Where do I find the Safety Switch for the "neutral " position? (automatic transmission)
The van won't start, and I don't hear the solenoid klicking.
I checked the battery ( + ) at the starter, is ok.
I also jumped the solenoid from battery ( + ) to the small terminal at the starter, is ok, engine turns over but does'nt start or run.
Thank you for your time
Bugworks
Old Jan 23, 2012 | 12:56 PM
TurboStixx's Avatar
TurboStixx
If it doesn't start when u have it in neutral, it is probably something else
Old Jan 23, 2012 | 02:17 PM
Bugworks's Avatar
Bugworks
That wasn't my question, but thanks anyway !!
I tested the wire from the solenoid to the plug undernees the fuse/relay box . is OK.
But in the same plug the solenlid wire meets with 2 smaller wires. Brown/White and White/Brown.
The safety switch was just an idea, because I can hear all the humming and other noises except the solenoid.
Thanks again Bugworks
Old Jan 23, 2012 | 02:26 PM
Cougar41's Avatar
Cougar41
"I can hear all the humming and other noises". If you can verify the starter relay is clicking when you turn the key to start, the park/neutral signal is getting to the PCM. When the PCM sees that signal it supplies the ground to the starter relay allowing it to close, creating the click.
Manual or 3 speed transmission uses the standard park/neutral switch mounted on the outside of the tranny. The 4 speed transmissions use the transmission range sensor mounted inside the tranny above the valve body.
Old Jan 23, 2012 | 02:29 PM
Tizzy1's Avatar
Tizzy1
unless you have a 3 speed transmission, the transmission has a range sensor inside that it uses to determine shifter position. when the PCM see's neutral or park, it will ground the starter relay.
