transmission shuttering
Old Jan 23, 2012 | 02:23 PM
rickker's Avatar
rickker
Cool transmission shuttering
Hi every one new here. check this out i have a 2002 dodge caravan 2.4 L . my transmission has a shutter when taking off and shifting to 2 ed gear. then perfect. does not do it the whole way through first just on take off. if you barely give it gas it wont do it. like driving over a wash board. i changed the cv s put new filter . a little better. any thoughts or similar experience out there. any help would be appreciated.
Old Jan 23, 2012 | 08:32 PM
bjr1a's Avatar
bjr1a
Do you have a three speed auto or a four speed?
Old Jan 24, 2012 | 06:45 AM
rickker's Avatar
rickker
Smile 4 speed
hi i have a 4 speed. thank you for taking time to answer back !!
Old Jan 24, 2012 | 09:40 AM
bjr1a's Avatar
bjr1a
I have every reason to believe that the Underdrive clutch set in the trans is failing.....It is applied in 1st and 2nd and releases in 3rd.....Possibly one of the snap rings has broken causing the clutch set to not apply correctly.......Be sure to check motor mounts / engine misfires and low fuel pressure for external concerns, but from what you described I think it would be internal...
Old Jan 25, 2012 | 09:09 AM
rickker's Avatar
rickker
Smile your right
took it to a shop you called it !! thank you for the incite and the time. best wishes
