1997 Dodge grand caravan, 3.0L engine won"t start
Old Feb 18, 2012 | 01:08 PM
dodgeone's Avatar
dodgeone
Default 1997 Dodge grand caravan, 3.0L engine won"t start
My 1997 Dodge grand caravan se won't start. It was starting every time until this time just as the engine was about to fire it stopped turning over.
After that it would not turn over anymore so I replaced the starter but it still won't turn over. There is power to the starter solenoid but the starter doesn't turn over at all.
Thanks for any suggestions.
Old Feb 19, 2012 | 12:23 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Have you tried to turn the engine over by hand?
Old Feb 22, 2012 | 04:10 PM
ShelbyGT550's Avatar
ShelbyGT550
You will notice there is a cover under the pass front of the van, Just inside a little from the wheel inner fender, Remove that and put a socket on the crank shaft bolt and try to rotate it.
