96 Grand Caravan 3.3L cold start problem.
Old Feb 19, 2012 | 02:43 PM
Averjoe's Avatar
Averjoe
Default 96 Grand Caravan 3.3L cold start problem.
I have a 1996 Grand Caravan that will not start in really cold weather (below 40 degrees). It cranks fine, starter sounds strong, but engine will not start. Once the weather warms up a bit it starts fine. Entire fuel pump assembly was replaced about about 15k miles ago and I can hear the pump when the ignition is turned on. Starter was replaced about 20k miles ago. Just put a new battery in it last month. Did the "key dance" and the codes it gave me were 12, 54 and 32.
Any ideas on where to go from there?
Old Feb 20, 2012 | 12:41 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Code 12 is battery disconnect, code 32 EGR system failure and code 54 no cam signal at the PCM. Inspect the EGR system and replace the camshaft sensor with a new mopar sensor.
Old Feb 20, 2012 | 07:42 PM
mbrahmer's Avatar
mbrahmer
I second replacing the cam sensor with a MOPAR dealer part.
