Oil coming from exhaust bolts
Old Mar 2, 2012 | 10:57 PM
wohugh's Avatar
wohugh
Default Oil coming from exhaust bolts
Hello. I have a '99 Dodge Caravan 4 cylinder. I've changed the valve cover gasket, knock sensor o-ring, and thoroughly degreased the engine. I've noticed oil coming from the exhaust manifold bolts. I don't believe oil is coming from the combustion chambers as the spark plugs are very clean. Can anyone please help?
Wood
Old Mar 3, 2012 | 10:44 PM
snosrap's Avatar
snosrap
would say the valve cover wasnt installed properly such as needing some rtv sealant in certain spots as specified by a haynes manual or such
Old Mar 4, 2012 | 10:59 AM
wohugh's Avatar
wohugh
No. I did install the valve cover gasket exactly how haynes described it by using rtv sealant around the neccessary locations! There is NO oil coming from the new gasket.
