2007 3.8 to 3.3
There was a post within the last two months that briefly talked about it but I can't find it... I believe it was said there that theoretically you can do it. The transmission should bolt up to the two different engines if they are of the same model year.
BUT
There are differences with wiring harnesses, the engine computer, certain sensors being different, the flex plate bolt pattern, depending on which model year, etc. It's not a plug-and-play situation. You will have to buy a lot more than just an engine, or alternatively pirate a lot from an auto wrecker, and knowing the individual pieces will be the research you will need to do.
For the average do-it-yourselfer, you are better off just finding the matching engine for your model year. Unless you are really looking for a project to keep you out of the kitchen and in the garage...
I have the 3.3 and have often thought I'd rather have the 3.8 because I find the 3.3 a little anemic on the highway. Why would you want to put the smaller engine in?
BUT
Yes you can, but....
I've gone both ways with these many times, as long as you get a replacement engine of the same year/generation 99.9% of the time you'll be fine. I used to worry about changing the PCM's but after doing a few found out it does not usually present any issues. Good Luck!
He may want to consider just swapping the engine and transmission together... that way he doesn't have any problems. He can always sell the good transmission. I know the gearing is slightly different between the transmissions for a 3.3 and 3.8 and though the 3.3 will move the car fine, it might be worth it for that reason too.
