Code P0205 and P0305
Old Mar 7, 2012 | 06:03 PM
Wellman's Avatar
Wellman
Default Code P0205 and P0305
I have a problem with my 2001 Grand Caravan running rough. I had a friend of mine pull the trouble codes up and they were P0205 and P0305. We erased the codes and they immediately came back up when vehicle was refired. Any help would be appreciated.
Old Mar 8, 2012 | 02:39 AM
Cougar41's Avatar
Cougar41
http://www.obd-codes.com/p0205
http://www.obd-codes.com/p0305
Good probability the P0305 is being caused by the P0205
Old Mar 11, 2012 | 09:00 PM
Wellman's Avatar
Wellman
Replaced fuel injector but didn't fix problem so I'm still searching for a fix.
Old Mar 11, 2012 | 10:36 PM
master tech's Avatar
master tech
Site Moderator & Tech
Take a look at the injector harness, the vans have had some problems with harness melting at the rear cylinder head. I also have PDF files if you need them.
