more brake problems
Old Apr 2, 2012 | 08:41 AM
Topher5150's Avatar
Topher5150
Default more brake problems
So I got a nice brake line from the junk yard to run from the ABS pump to the brake hose on the drivers side. I put it in filled it up and pressed the brake pedal a couple of times and it's dumping fluid from the ABS pump. What should I check for
Old Apr 3, 2012 | 10:35 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would have someone step on the pedal and inspect the line at the abs pump for leaks or the pump itself.
Old Apr 8, 2012 | 05:08 PM
Topher5150's Avatar
Topher5150
I thinker I may have gummed up some of the thread scan it be re-tapped
