Caravan sliding door won't unlock
Old Apr 14, 2012 | 03:25 PM
Jon Mopar's Avatar
Jon Mopar
Default Caravan sliding door won't unlock
03 Caravan SWB w/power locks. The pass-side rear door won't unlock with the power locks, and I can't seem to unlock it manually either. Anyone experience this??
I just decided to act up today.
Thanks
Old Apr 16, 2012 | 03:36 PM
Tizzy1's Avatar
Tizzy1
The lock actuator probably bit the big one. Pretty common.
Old Apr 17, 2012 | 12:44 AM
Jon Mopar's Avatar
Jon Mopar
Can that be taken apart with the door closed?? (because I can't unlock it and all)
Old Apr 17, 2012 | 01:22 AM
CompSyn's Avatar
CompSyn
The 02 I just bought has a similar problem with the passenger side slider as well, although I can manually lock and unlock the door via the ****.
Guess I'll be looking into replacing the actuator soon...
Old Apr 17, 2012 | 05:40 PM
Jon Mopar's Avatar
Jon Mopar
Isn't it odd that I can't unlock it manually though?? I pull on the lock tab all I want, it won't pop to the "unlocked" position
Old May 9, 2017 | 03:19 PM
David Sawyer's Avatar
David Sawyer
I have the Same problem on my 2004 - I can not pull up the door lock **** - it is stuck in the down position and as STUPID AS IT SEEMS ! - It is a catch 22 situation ! -You need to open the sliding door first !! - in order that you can remove the door panel to get access to the Locking mechanisms - - - But the door is locked & will not Open - so I can not get the interior door panel off and that's pretty frickin STUPID - !!:icon_rof lmao:
