P0200 on2001 dodge caravan 2.4
Old Apr 16, 2012 | 05:50 PM
HappyHound's Avatar
HappyHound
Default P0200 on2001 dodge caravan 2.4
I change the water pump & timing belt, engine runs but only if I keep the gas pedal down a little p0200 code shows. How can I fix this or should I take to shop? TOL
Old Apr 16, 2012 | 11:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
Have you recheck your timing marks?
Old Apr 17, 2012 | 05:33 PM
HappyHound's Avatar
HappyHound
No I haven't, but b4 I put everything back together, I started the engine & let it run briefly my marks are as follow (RT@ 9,LT@ a/b 3:30,BT@ 12) I thought that the code I was getting was a fuel issure not a fire. Is there away to check the timing w/o taking it back down? & if so, is there away to set timing other than tearing it back down? TOL...
Old Apr 18, 2012 | 12:00 AM
master tech
Send me you email address, this way i can send you a picture on how the timing gears should line up.
Old Apr 18, 2012 | 11:40 AM
HappyHound's Avatar
HappyHound
johnathanbarrow@gmail.com
Old Apr 21, 2012 | 07:29 AM
HappyHound's Avatar
HappyHound
For some reason I seem to find your email..... I've sent a pm to you with another....tol..!!
Old Apr 21, 2012 | 07:31 AM
HappyHound's Avatar
HappyHound
I meant can not find.....
