'O4 Transmission Problem [ P0846 ]
Old Apr 22, 2012 | 02:23 PM
LWK3113's Avatar
LWK3113
Default 'O4 Transmission Problem [ P0846 ]
It has been a difficult month as I have still not solved my P0306 misfire code. Seperate thread
I own an '04 Caravan 3.3L "R"
My Transmission went (failed @ 216K miles) and I purchsed a Nused 2003 Transmission with 62K miles. My Mechanic had to use the original Output Speed sensor as the one on the 2003 transmission we purchased was damaged.
After the swap, things went great for ~100 miles (3days) and then a P0846 [ 2/4 pressure circuit ]showed up today. He has a Snap-on Scan tool [SOLAR] and asked me to come here and ask for some insight as the Scan tool shows the Input Sensor switch to be +/- 50 RPMS from the engine readings.
He wanted to know if there was some insight from an experienced member he/she might be able to pass along.
Thanks in Advance,
Lloyd
