2008 Caravan vent fan issue
Old Apr 30, 2012 | 10:03 AM
xobxdoc's Avatar
xobxdoc
Default 2008 Caravan vent fan issue
Going back to the Dodge Dealer for the third time for vent fan problems. Does anyone know of issues with the vent fan that Dodge knows about? I'm taking my vehicle back in for the 3 rd time in four months because my vent fan keeps cutting off. The last time Dodge replaced a computer board at my cost of course and said this was the problem this time. They are apparently just fixing the symptoms and not getting the cause. I'm into them for over $900.
Old Apr 30, 2012 | 04:15 PM
Cougar41's Avatar
Cougar41
Don't have access to my wiring diagrams right now but as I recall the circuit board within the TIPM (fuse box) controls power to the front blower on an 08. Is that what they changed? $900 sounds about right for a TIPM change.
A dealership with any concience would reimberse you for the non fix in some way especially at $900. Start jumping on someones desk or call this "Chrysler Cares" line I keep hearing about.
As for a fix? Realy could be any number of things. Loose connection, bad contacts within a connection, wiring, the HVAC panel switch, the blower motor itself or it's controller under the dash. I have read of the TIPM fixing it.
A known blower problem? Nothing I know of specific to 08s but then I'm not a tech. Sad thing is judging by posts on this and other forums the blower system is a problem across the board for many makes and models.
Old Apr 30, 2012 | 10:06 PM
steak59's Avatar
steak59
It could be the Fan Motor itself... fairly common failure.
the circuit board(tipm) is a common failure. I've seen bad A/C control heads and bad blower resistor causing blower to cut out too.
Honestly, there isn't a 100% answer to your problem, you really just have to test it when it is "Cutting out", not much you can do when everything is operating normally.
Old May 1, 2012 | 09:31 AM
xobxdoc's Avatar
xobxdoc
Thanks for the responses. My first trip in the shop replaced the blower motor. My second trip replaced the circuit board. I still have the same symptoms. Right now after several minutes of operating , the fan will cut off. After letting it sit for a while, the fan will turn back on but eventually cut off again. Is there a thermal overload associated with this fan?
Old May 2, 2012 | 12:34 AM
steak59's Avatar
steak59
The question is, Which circuit board? there are like 3 computer module related to Blower motor operation. Does the reciept says "A/C control unit, Blower Motor Power module, Blower resistor, TIPM, or something like PDC(power distribution center)?
No thermal overload, There is a Fuse, but if that's blown, your blower will flat out not working at all.
