please help
Old Aug 19, 2005 | 12:52 AM
dodgenewbie's Avatar
dodgenewbie
Default please help
just bought the wife a 96 caravan 3.0 3 spd nice van but it has two problems . motor runs great but when you put it in gear it stalls drive or reverse it doesnt matter the guy i got it from said if you put it on the lift and put it in gear it will run fine and tranny works fine but if you put it down on the ground and put it in gear it stalls then he said if you rev it up and put it in gear it will start going but dont stop or it will stall . second problem is the gas gauge doenst seem to work but if someone can help with the tranny i would really appreciate it
Old Aug 19, 2005 | 01:31 AM
tenntech's Avatar
tenntech
Default RE: please help
The stalling problem would almost have to be a torque converter staying locked all the time. The fuel guage could be any number of things, like a fuel level sending unit, a bad fuel guage, or wiring problem.
Old Aug 19, 2005 | 01:52 AM
dodgenewbie
ok if its staying locked how do i fix it
can someone tell me how or give me a web site that would show me
Old Aug 19, 2005 | 11:15 AM
Toecutter's Avatar
Toecutter
My 96 3.0 gas gauge is wiggin out goes up and down then sends the 'low fuel idiot light on. The Sending unit on that Mod is part of the fuel pump as well.....(Thanks Dodge) Your local parts store has them for 156.00 approx. Dont want to give free advertisement to auto parts stores, so look under stores that start with the letter "A" if you know what I mean. Now on to your Trans... If you remove your air box take a light and look down you'll see a 2 pin conector pluged into the right side of the trans i think there's two diff ones so you'll have to scope it out your self. Your hands prob wont fit so get some long needle nose or just shove your hands down there and give it a try. OK, now what this pin cont. does is engage your lock out un plug it see if the trans works at all. Its just helps @ speeds of 45 mph apprx. If that doesnt work pull your dip stick and smell the trans. fluid. If its burnt smells like it or if its not a rose/pink color. I'd pull your pan and replace the pick-up filter. from the factory you'll see black silicone sqwishing out from the pan. this way you know no one has been there since you have bought the van. I also have the procedure to flush out the entire trans system, If you'd like. If not bring it to a garage and have them do it. Im assuming you know how to turn a wrench.
DONT FORGET: use only ATF III in your trans.
Hope this helps,
Toe
