could this void my warranty
Old Jun 27, 2012 | 12:47 AM
2011caravan's Avatar
2011caravan
Default could this void my warranty
I want to add cold air intake to my caravan could this won't void warranty ??
Old Jun 27, 2012 | 11:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you know if it mopar approved part?
Old Jun 29, 2012 | 10:46 AM
thevalleyboy's Avatar
thevalleyboy
Do you really think a CAI to a 283HP V6 is really going to do much? I am guessing it will not, but keep us posted if you do, not sure where the cold air will come from unless keeping with the stock intake, does anyone even make one for the Caravan?
Old Jun 29, 2012 | 08:19 PM
steak59's Avatar
steak59
Haven't seen anyone install one yet. I would think it could get into the way of the Oil Filter when you do Oil change, I don't see how can you install one.
There aren't aftermarket stuff that VOIDS the waranty, buy a Manufacturer could deny a waranty claim in case of a failure DUE TO the aftermarket part you installed.
Let say if your air filter falls apart and gets suck into the engine, Chrysler will not buy you a new engine. (happens in Diesel trucks)
But let say your engine throw a rod or something, and you have been doing you oil change, and it isn't related to the CAI, chrysler will buy you a new engine.
But let say you installed a Turbo charger into you car, yeah... your waranty is void.
Old Jun 29, 2012 | 08:33 PM
dakotaff's Avatar
dakotaff
Keep your stock intake, just in case. Any problems, simply swap the stock intake back in.
It's easy & quick to change them.
Old Aug 13, 2012 | 10:11 AM
Chedman13's Avatar
Chedman13
No, but the dealership could potentially give you a hard time if you need to do warranty services in the future.
Please do share your findings on a cold air intake (CAI) if you come across one or make one yourself.
http://www.ftc.gov/bcp/edu/pubs/cons...ts/alt192.shtm
http://en.wikipedia.org/wiki/Magnuso...s_Warranty_Act
"The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket or recycled part. Still, if it turns out that the aftermarket or recycled part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage."
