2002 Caravan will not start
Old Jun 28, 2012 | 07:08 PM
bcrisp's Avatar
bcrisp
Default 2002 Caravan will not start
HELP!!! I cannot seem to figure out why my Caravan died on me. While driving i started hearing some noises like it was running rough and then the oil light came on and it died shortly after. When we tried to start it, it would try to turn over but not start. We checked the plugs and they were covered in oil. We used carb cleaner and soaked up what was remaining and then put new plugs in and havent seen any oil in there since. We were able to get it to start by pumping the gas repeatedly but it died out shortly after. The timing belt is intact, we are getting spark and fuel (checked fuel pressure and replaced the filter... pump seems to be working fine too.) We are thinking some kind of sensor possibly but at this point we cannot narrow it down. Any suggestions?? Thanks.
Old Jun 28, 2012 | 09:15 PM
Cougar41's Avatar
Cougar41
Spark, fuel or compression are missing. You say you're getting the first two. How about #3? All that oil could indicate a cracked head/block, or a simple PCV valve.
Old Jun 28, 2012 | 09:20 PM
dsolorio's Avatar
dsolorio
Were ALL the plugs covered in oil? If yes, I would imagine oil came up through your intake system. PCV valve good?
