2001 caravan 3.3 rough running
I have a 2001 caravan 3.3 runs rough dies showing codes P0106 P0107 changed map sensor tune up coil packs.will run fine for a few min and starts all over again "PLEASE HELP"
Welcome to DF
Check the wire haness on the rear cylinder head, that is the injector harness and the wires to the map and TPS sensors. You may need to open the harness and inspect for burnt or melted wire.
