1995 Caravan stalling issue
Old Jul 17, 2012 | 09:24 AM
bigtuna's Avatar
bigtuna
New Member
Default 1995 Caravan stalling issue
I have a 1995 Dodge Caravan SE with the 3.3L engine. Problem started while driving where the engine stalled at 55mph. Would not restart. Cranks but not starting. Replaced the ingition coil, cam position sensor, crank position sensor, and engine control computer. Finally got it to start and run but still will stall after a few miles of driving. Will restart but the stalling continues. Checked fuel pressure with a guage at the rail and that was fine. Also checked vacuum and that appeared fine. I have tapped / hit / swapped every dang relay and the ignition switch as well. The check engine light has never lit and I do not believe there are any codes. Battery is strong and the fuel pump was replaced 2 years ago. Any help would be appreciated...
Old Nov 12, 2012 | 01:58 PM
packermom28's Avatar
packermom28
this is the same thing that is happening to me also. If anyone has an answer please let me know. thank you
Old Nov 25, 2012 | 10:17 PM
MikeMan65's Avatar
MikeMan65
Try replacing your EGR Valve
