Installing HID lights
Old Aug 7, 2012 | 07:29 PM
Darkside 700's Avatar
Darkside 700
Default Installing HID lights
I am wondering on a 12 Canadian Grand Caravan if the DRL's are powered at full voltage or is it pulsed. I would like to install a HID light kit in and wanted to know if I require capacitors/canbus kit to keep the lights from flickering. I would rather do it this way instead of running the power to the ballasts thru relays. Thanks in advance for your help.
Old Aug 8, 2012 | 11:55 AM
Tizzy1's Avatar
Tizzy1
I believe on the HID systems, they run the DRL through the high beams. And yes, it is pulsed.
Old Aug 9, 2012 | 11:38 AM
Darkside 700
Thanks Tizzy1
I just picked up the van last night and yes the drl's are on the high beam.
I will get the capacitors.
Old Jun 27, 2013 | 03:26 PM
laserman42's Avatar
laserman42
Default HID on Low Beams
Further to your question.
If you install HID lights on the low beam are the capacitors or any special hookup required?
DRL are on High beam?
Also 35 or 55 watts?
Old Jun 28, 2013 | 10:50 AM
Darkside 700
Laserman42 the low beams do not require capacitors due to they come on with steady 12v power the DRL's are your high beams that are pulsed as to dim there output. You will need capacitors or supply power thru relays the only thing is that you will have your high beams on at full brightness.
I went with the 35 watt kit with a color temp of 4300K a nice white light
Old Jul 2, 2013 | 04:31 PM
laserman42's Avatar
laserman42
Thanks... Low Beam HID's it is then.
Old Jul 26, 2015 | 07:54 PM
ceasarjr8o8's Avatar
ceasarjr8o8
I have a 2015 Caravan RT. Do we need a Canbus HID Kit for the foglights?
Old Jul 27, 2015 | 10:44 AM
Darkside 700
ceasarjr8o8 you do not require the canbus as the voltage is a steady 12 volt
Old Jul 27, 2015 | 01:19 PM
ceasarjr8o8
Thanks Darkside!
Old Jul 27, 2015 | 02:29 PM
RickMN's Avatar
RickMN
You're replacing the entire headlight assembly, right? Cuz a drop in HID kit is illegal and actually throws less light on the road. You must have a headlight that's built for the different focal point of HID bulbs. And it must be built to handle the extra heat.
