Heavy duty oil pump for 1994 3.9 V6
Old 08-25-2005 | 01:46 PM
c903's Avatar
c903
Default Heavy duty oil pump for 1994 3.9 V6
Anyone know what is a good brand after-market heavy duty oil pump for a 1994 Dodge 3.9 V6? Also, is it wise to increase the oil flow pressure on an engine having 130,000 miles? Would I also have to change the pick-up in the pan?
Old 08-28-2005 | 01:37 AM
hemipower1984's Avatar
hemipower1984
Default RE: Heavy duty oil pump for 1994 3.9 V6
recommend replacing pickup if you replace pump. but putting a high volume pump may not be good because they can pump to much oil and not leave enough oil in pan sump to pump oil.
Old 08-28-2005 | 06:04 AM
c903's Avatar
c903
Makes sense to me.
Being I am not pulling a heavy load, I believe I will just install new (standard) pump and pick-up so that I know everything is up to par.
Quick Reply: Heavy duty oil pump for 1994 3.9 V6
