Can't start my Caravan 8-(
Old Aug 8, 2012 | 09:03 AM
PB Stow'n Go's Avatar
PB Stow'n Go
Default Can't start my Caravan 8-(
Last night, I went out, drove a few kms, came back home; a few minutes later, I went to go back out, could start the engine. When I turned the engine, I heard a chattering noise, sounded like a mechanic's air wrench; I noticed the gauge needles shoot clockwise all the way, but then settled back to zero after I released the key. Checked under the hood with a flashlight, didn't see anything unusual. Just in case there is connection, I did drive thru a heavy rainstorm on saturday.
It is a 2007 Grand Caravan, with a 3.6 L, 105,000 km on the odometer.
Old Aug 8, 2012 | 01:25 PM
Cougar41's Avatar
Cougar41
Chattering relays and erratic instruments usually means weak power. Make sure your battery connections are clean and tight. Charge the battery using a charger. If the battery is 5 or more years old consider a new one. You could try jump starting the van with jumper cables. Hardly worth mentioning but on extremely rare occasions and I stress extremely, you can damage electronics on the van when jump starting.
Old Aug 9, 2012 | 07:52 AM
PB Stow'n Go
Default New battery worked like a charm!
Thank you Cougar41, I got a new battery on my way home after work. I had no problems starting the van after I popped the battery in. Saved me from towing the van to a shop to have it checked out.
Cheers!
Old Aug 9, 2012 | 07:36 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
how your 2007 have 3.6l? did not they release that only 2011 and up?
