97 tranny shift question
Old Aug 26, 2012 | 10:23 AM
bonesbmx's Avatar
bonesbmx
Default 97 tranny shift question
my ram finally died and met its fate in the shredder at work. i just picked up a 97 caravan. it is great. start and run every time, BUT for 1 problem. when i shift from first to second it sort of jerks a little. not to hard but enough that i can feel it. the rpms rise and hold for a second before the shift to second. i read here it may be the tps. my ram never had any tranny issues in all the years i owned it. i guess im looking for all the cheaper things i can do before i take to a shop.
97 3.0
there are no service lights on, speedo is good, all other gears are fine.
thanks guys.
Old Aug 26, 2012 | 04:35 PM
Cougar41's Avatar
Cougar41
Try changing the fluid and filter first. That simple move has fixed many hard shift problems. Use only ATF+4 fluid.
Old Aug 27, 2012 | 12:25 AM
master tech's Avatar
master tech
Site Moderator & Tech
If you have a 3.0L in the van, do you know if you have a 3 speed trans or the 4 speed?
Old Aug 27, 2012 | 04:05 PM
bonesbmx's Avatar
bonesbmx
sorry guys. i belive its the 41te trans. the fluid and filter were done about a year ago. im going to try the input and output speed sensors.
