2002 Caravan AWD Brake Pedal Pulsing Please Help
Old Aug 31, 2012 | 01:11 AM
Nate718's Avatar
Nate718
Default 2002 Caravan AWD Brake Pedal Pulsing Please Help
I have a 2002 Caravan Awd I just got it from a friend and I noticed
the Pedal Pulses when stopping but it feels fine in terms of Firmness
My Mech suggested replacing the Abs Pump and so I had him replace
it but the problem still exists
Any info Would be Greatly Appreciated
Old Aug 31, 2012 | 04:05 AM
Cougar41's Avatar
Cougar41
Did your mech look at the front brake rotors? That's the typical cause.
Old Aug 31, 2012 | 07:53 AM
grswat's Avatar
grswat
More than likely warped rotors. Get new mechanic.
Old Sep 1, 2012 | 07:15 PM
Nate718's Avatar
Nate718
Thanks a lot guys it was the rotors
Old Sep 2, 2012 | 01:16 AM
Cougar41's Avatar
Cougar41
Now you have a question to answer. Did you explain the problem properly to your mechanic? If you think you did, you need to find another mechanic. I can only hope you're not telling us the whole story. Warped rotors is a basic first step when troubleshooting pulsing/vibrating brakes. An ABS pump is way down the list. Even then it's very easy to eliminate as a cause. If he didn't know that he needs to go back to school, if he ever went.
