Old Aug 4, 2015, 08:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
need help before buying a dodge caravan
Old Aug 31, 2012 | 01:59 AM
coco-nuts's Avatar
coco-nuts
Default need help before buying a dodge caravan
hello guys, i have a meeting to see a dodge caravan tomorow night, the problem is that i don't know much about this car. Can you tell me the bad things about this car, the spots i need to check before buying (for exemple something of the engine or the drive train). Is there some important issues thats need to be check. i'm kind of repeat myself but i want to be sure you guys understand (i'm french so my english is not so good).
so the model is a dodge grand caravan sport, suppose to be a 3.3l v6 engine of 2003 with 201000 kilometers.
the guys just replaced this:
"Front struts - Both
Front sway bar bushes - both
Sway bar linkages - right hand side
Resealed and regssed the air conditioning
oil changed
do you think that the struts and front sway bar are suppose to be changed a 200000km or it is a Ill-treatment from the driver?
One last question is there a manual for maintenance where i can find the operation that need to be done on the engine for the check up ( like for the check up of the 150000km the oil and the filter and stuff needs to change for exemple).
thanks in advance for your help, if i have not been clear, tell me and i try to be clearer.
have a good night.
Old Aug 31, 2012 | 03:56 AM
Cougar41's Avatar
Cougar41
Based on the parts changed it looks like someone was chasing the all to common front end noises 4th generation vans are plagued with. They can happen at any mileage. Make sure they are gone on the test drive. Not really a safety issue, more an annoyance.
Typical 2003 problem areas are the electrical system especially lighting and the middle power sliding doors. Make sure all are working good. Look at the fuse box in the engine compartment making sure there's no visible evidence of corrosion. It's been the cause of many problems.
Here's a maintenance schedule and access to recalls and TSBs. Just punch in your info: http://www.edmunds.com/car-maintenance/guide-page.html
You'll just have to convert miles to kms.
Old Aug 31, 2012 | 07:55 AM
grswat's Avatar
grswat
Check for rust on the upper strut towers. Transmissions are hit and miss.
Old Aug 31, 2012 | 07:57 PM
coco-nuts's Avatar
coco-nuts
Thanks for the help guys, lets hope this car is in good shape.
