2008 dodge grand caravan
Old Sep 2, 2012 | 11:59 AM
GILTORRESJR76's Avatar
GILTORRESJR76
Default 2008 dodge grand caravan COOLANT TEMPERATURE SENSOR??
GOOD AFTERNOON TO ALL,
My 2008 check engine light came on, when i took it to autozone code p0128 faulty coolant temperature sensor came up but i have no clue where its located???
Any help would be much appreciated,
3.8 L engine also. ive looked all over and cant find it so im hoping the Dodge Family can help.
Gil
Old Sep 2, 2012 | 09:57 PM
georgef's Avatar
georgef
If you remove the coil pack you will see the coolant temperature sensor is located beside the heater supply fitting.
Old Sep 3, 2012 | 09:55 AM
GILTORRESJR76
Is the coil pack difficult to remove?
Old Sep 3, 2012 | 08:55 PM
georgef's Avatar
georgef
Very easy to remove.
1. Disconnect and isolate the negative battery cable at battery.
2. Remove the ignition cables from the ignition coil.
3. Disconnect the electrical connector from the ignition coil.
4. Remove 2 nuts from the ignition coil studs.
5. Remove ignition coil and bracket from engine.
Old Sep 4, 2012 | 09:12 AM
jimbo111@yahoo.com's Avatar
jimbo111@yahoo.com
Thanks Georgef, need to replace the same part but couldn't find the location of the temp sensor.
By the way, were are you getting those great pics from? A good service manual would really help get things done.
Tar
Old Sep 4, 2012 | 10:29 PM
georgef's Avatar
georgef
The pictures are from my 2001 Caravan Service Manual, but the 3.8 L engine hasn't changed much since then.
Old Nov 24, 2016 | 02:01 AM
Sasz's Avatar
Sasz
good day!
I'm planning to replace my coolant sensor, do I need to flush out the coolant first or can I just remove the pressure cap from the radiator?
thanks!
