start no run
Old Sep 22, 2012 | 11:14 AM
rhino1961's Avatar
rhino1961
Default start no run
The battery went dead on my 98 caravan, The next day it started, and I let it run for a while to charge. I shut it off and restarted to check if it would, problem is now it wont stay running unless I keep my foot on the gas, as soon as I take it off it stalls.
Old Sep 22, 2012 | 12:49 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
well i get the battery checked but i have a feeling it may not be the battery. Could be the alternator issue. i would see if u could put a slow charger on the battery for the required time and then replace it in the vehicle. i think you read like 14 or more volts not running but running i think it should not go less than 12.
Old Sep 22, 2012 | 05:15 PM
b1lk1's Avatar
b1lk1
You got that backwards. you want to see 13.5V+ when running and 12V-12.5V when the vehicle is completely turned off.
You may just have a car that is cranky when it has to relearn everything. While not common, I've had a few vehicles in my lifetime that did exactly what you said and there were no other faults.
Old Sep 22, 2012 | 06:50 PM
rhino1961's Avatar
rhino1961
now I have a strong smell of fuel, still wont stay running if I let off of the gas pedal. I dont have to rev it much to stay running
Old Sep 22, 2012 | 09:51 PM
DodgeCaravan2010SXT
you correct .
Old Sep 23, 2012 | 12:24 PM
rhino1961's Avatar
rhino1961
I have around 11 not running, and 12 running, but still have the fuel smell when I rev it. I never had a fuel smell before this.
Old Sep 23, 2012 | 12:49 PM
rhino1961's Avatar
rhino1961
Ok inst. cluster went out now it runs fine, and no gas smell, think I found the problem..... correct?
Old Sep 24, 2012 | 12:55 PM
rhino1961's Avatar
rhino1961
Did not trust my meter so I went to the auto store, turns out I have 12.5 not running and 8.9 running, but on the plus side t started and ran fine today.
Old Sep 24, 2012 | 03:35 PM
Cougar41's Avatar
Cougar41
Auto store should have tested your alternator. As stated you should see around 14vdc with the engine running as measured at the battery posts.
Old Sep 24, 2012 | 05:51 PM
rhino1961's Avatar
rhino1961
they said the alt. was good so I bought a new battery, so far so good, but I still have to deal with the instrument cluster.
