1995 Caravan Overheating - Help!
Old Sep 24, 2012 | 03:56 PM
depkerf's Avatar
depkerf
Default 1995 Caravan Overheating - Help!
a week ago I drove across town and at around 5 miles I noticed the Temp guage go to "H". Soon after, the engine shut down.
I let it set 20 minutes or so and added water. Drove it a very short distance to a repair garage. They noted that the fuse to the fan had blown and they said they cleaned the connection that they thought was the cause. That worked for a while until I drove across town again and it did the same thing.
I'm guessing there are probably 5 things that could be causing this.
Any suggestions? Anyone else have this happen, and if so what fixed it for you? Thanks<
Old Sep 24, 2012 | 11:24 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Check the fuse again and if it blown, then replace the fan module.
