Cranks but no start
Old Oct 9, 2012 | 03:44 PM
gwhizz55's Avatar
gwhizz55
Default Cranks but no start
2003 Grand Caravan. Changed plugs and wires, now will not start. I am getting fuel at the rail. Appears to be no spark. Replaced coil pack. Tried new PCM. Still no luck. What could I be missing. Please help a unlucky one.....
Old Oct 9, 2012 | 08:29 PM
Cougar41's Avatar
Cougar41
No cam/crank sensor signal will cut power to the coil.
Old Oct 10, 2012 | 10:18 AM
gwhizz55's Avatar
gwhizz55
I replaced this AM both crank and cam sensors. Still no luck. I guess check for broken wire would be next. About to give up!!!!
Old Oct 10, 2012 | 02:27 PM
steak59's Avatar
steak59
are you getting power to the Coil? Check it with your test light first when Cranking. Power comes from ASD relay and fuse. Sometimes the problem is the Power Distribution center has internal failure, Cutting out the power flow to Coil and injectors.
Old Oct 10, 2012 | 09:06 PM
gwhizz55's Avatar
gwhizz55
Checked power to coil when cranking. Test light shows power. My gut feeling is broken wire in harness somewhere but, I have been wrong once before. Wish I had a wiring diagram!!
Old Oct 10, 2012 | 09:57 PM
steak59's Avatar
steak59
I recommend you to purchase a subscription from Alldatadiy.com for like $45. They have a complete wiring schemetic and Repair manual.
Honestly, I am having a 03 Caravan with the exact same problem sitting the parking Lot for 2 weeks alrdy. No CEL, no Spark, have power to coil, and I got Crank and Cam signal. Just no Coil Pulse from PCM. I'll see if I can find anything on it later this week.
Old Oct 11, 2012 | 10:00 AM
gwhizz55's Avatar
gwhizz55
Have a buddy who knows a buddy who has equipment for checking into issue. Will let you know what happens. Most likely won't happen until Saturday. Hope problem isn't to in depth... Running out of money shotgun troubleshooting...
Old Oct 11, 2012 | 08:25 PM
steak59's Avatar
steak59
Lol, Mines probably has a bad Fly wheel, PCM is not reading RPM right... Wires checks out ok. I'll need to pull the trans out later to see what I can find.
If you have friends with Scanner, read the RPM data while cranking. And Make sure you check for the 8 volt reference to the Crank and Cam sensor.
here is your wiring diagram if you need to check wires.
Old Oct 12, 2012 | 09:38 AM
gwhizz55's Avatar
gwhizz55
Thanks. I checked 8 VDC, 5 VDC and 12 coming into PCM. All there.... I'll check RPM on Sunday. Let you know what's up... Keep Smiling
