'98 Caravan - Ignition kill switch
Old Oct 13, 2012 | 11:37 AM
pcexhaust's Avatar
pcexhaust
Default '98 Caravan - Ignition kill switch
All,
My '98 Dodge Grand Caravan was stolen. The thief popped out the ignition cylinder and started it with a screw driver. I just paid a mechanic to replace the ignition switch so I could stop using a screw driver to start the vehicle. I would like to put a kill switch in place to make it harder to steal the van again. I think the best thing is to put a switch inline between one of the wires on the harness that connects to the ignition switch.
I'm a pretty handy person and understand electronics. I'm looking for a starting point so I can go figure out (Google) what needs to be done. What wire should I break with the switch? How much current is going across that wire? I was hoping for a low current wire. What is the name of this wire? Any idea what color it is?
Thanks!
Old Oct 14, 2012 | 04:50 AM
papaduck's Avatar
papaduck
Instead of disableing the ignition, disable the starter.
Old Oct 14, 2012 | 08:24 AM
pcexhaust's Avatar
pcexhaust
If I put a switch inline with the cable on the ignition switch harness called "starter wire" isn't that the same thing? It seems that the starter wire will be less than 10amp and it would still be to keep the car from starting. Thoughts?
Old Oct 14, 2012 | 06:01 PM
Cougar41's Avatar
Cougar41
Yes same thing. Suggest using a relay, switch and fuse. A relay will free you up to use just about any switch rather than a bulky switch to handle the power.
