2008 Caravan front overhead console disasembly
Old Nov 11, 2012 | 01:36 PM
zomgqwert's Avatar
zomgqwert
Default 2008 Caravan front overhead console disasembly
Hello fellow Dodge drivers! I have a 2008 Grand Caravan (it was one of the basic ones without most of the fancy gadgets), and I need to get to the wiring that is running on the overhead lights in the front. Normally I can find out how to do it, but this thing looks like a solid piece with no visible trims. The only place that I see that could be accessible would be the cover where the switch bank would be. If anyone has an idea on how to open this up, feel free to post.
Old Nov 12, 2012 | 11:15 AM
Tizzy1's Avatar
Tizzy1
2. Using a trim stick C-4755 or equivalent, disengage the retaining clips at the front edge of the overhead console (1). 3. Once the front edge is released use your fingertips to grasp the sides of the overhead console (2) and pull straight down evenly to disengage the remaining two retaining clips from the mounting bracket.
The front edge is the end closest to the lamps, not the windshield. Pretty much just held on by clips.
