Neutral Safety Switch
Old Nov 16, 2012 | 07:43 PM
solracluar's Avatar
solracluar
Unhappy Neutral Safety Switch
I need help, I cannot locate the NSS on my 2000 Dodge Caravan, 3.3 L engine, I already changed the input and output sensors but I could not locate the NSS, if the one helping me be very specific because IŽam not a very good mechanic.
Thanks!
Old Nov 16, 2012 | 08:50 PM
Cougar41's Avatar
Cougar41
Sounds like you have the 41te 4 speed transmission. You won't find it on the outside of the transmission. You have a Transmission Range Sensor (TRS) instead of a NSS. It's mounted inside the transmission above the filter and valve body. It does have an external electrical connector right front next to gear shaft.
Old Nov 17, 2012 | 01:24 PM
solracluar's Avatar
solracluar
No, my caravan is a 3 speed
