2002 Grand Caravan AC Clutch Bearing?
I noticed a different sound under the hood and investigated. It goes away when the AC engages.
I took tension off the belt and can wobble the AC compressor pulley a little. So I guess its the clutch/pulley bearing?
Is this a press-on thing? Can that bearing be swapped out easily enough perhaps with a puller.
The AC cools fine.
Thanks!
The AC cools fine.
Thanks!
Self reply here. I found a U-Tube video on the Denso compressor found in mini vans and some Honda's.
Not sure if Tube vid links are allowed here so just remove the dashes between the you & tube.
http://www.you---tube.com/watch?v=xrB3pMVD4Cg
Found the bearing on eBay, NSK OE quality. Seller name "allforauto".
Thanks
Thanks
