need help with trans variable force solenoid
Old Dec 14, 2012 | 09:54 PM
chokeout's Avatar
chokeout
Default need help with trans variable force solenoid
I have a 2007 dodge grand caravan and the trans variable force solenoid burnt to a crisp i need to know if anyone has ever taken one out and do the pull straight out or do i have to take bolts out somewhere because i cant get ahold of it very well since it is broke very close to tranny and its a tight squeze gettin in to it would really like to find out how it comes out
Old Dec 15, 2012 | 08:15 PM
go-part's Avatar
go-part
Former Vendor
You have to remove the valve body first, it is in the oil pan. Then there are 3 screws holding the solenoid down to the valve body.
Old Dec 17, 2012 | 08:02 AM
grswat's Avatar
grswat
How did you determine that was your problem? Had to google it just to see what it was. http://www.moparpartsoverstock.com/s...ssembly=899671 There is a diagram of the valve body on that page if that helps you any.
