Has Anyone Swap a 3.8 into a 3.3 2002 GC?
Old Dec 21, 2012 | 10:39 PM
2therock's Avatar
2therock
Default Has Anyone Swap a 3.8 into a 3.3 2002 GC?
I searched but my terms aren't doing so good.
Has this been done and discussed anywhere. So far all I see is a flex plate issue.
Would want my tranny for the lower gears. I think.
Old Dec 24, 2012 | 08:00 AM
grswat's Avatar
grswat
The 3.8 has a knock sensor but if the computer isn't looking for the signal it shouldn't be a problem. Flexplate should be the same.
Old Dec 24, 2012 | 10:13 AM
2therock's Avatar
2therock
Wow, plug and play wiring?
Old Dec 26, 2012 | 08:57 AM
grswat's Avatar
grswat
Assuming both engines are around the same year sensors should all be the same.
Old Dec 26, 2012 | 11:38 AM
2therock's Avatar
2therock
Thanks but I know better than to a$$-ume if you know hat I mean. I have searched some and among the results I hear a flex plate may be an item of interest. I would love to hear from one who has done it though.
I also found a site where a gentleman experimented with forced induction on a 3.3 and blew a hole out of the block in the process. It was done in a lab just to see what would happen.
In that article I read a spec chart showing the 3.8 to be 23 more HP than the 3.3.
I plan on keeping this van and the Motor seems fine but for a slight vibration @ idle in gear. I am trying to run that down now.
I want to look at a 3.8 possibility for mounting on my 3.3 transmission for its lower gears than normally come with the 3.8.
I am contemplating in gathering it up and building/repairing/nurturing it in my shop at my leisure.
@ 125+k and my driving style I may want to be ready. I figure if and when my trans goes I'll do it all. If not my siblings can fight over it when I'm gone.
Old Jan 1, 2013 | 11:14 PM
mbrahmer's Avatar
mbrahmer
The gear ratio in the transaxle is different and may cause an unwanted effect from the TCM. My swap is removing the 3.3 and replacing it with a 3.8 and the AWD transaxle. I have the TCM and PCM from the AWD donor.
