Engine Light 2006 Grand Caravan 3.8
Old Jan 6, 2013 | 10:53 PM
Ole Goat's Avatar
Ole Goat
Question Engine Light 2006 Grand Caravan 3.8
For some reason my engine light comes on, damm eltronics. anyway last week when the engine light appeared I checked engine oil level it was okay, washer bottle was near dry filled that.
Drove up the road about 2 miles engine light went off. Today the light returned, washer bottle was low from use so refilled it, checked oil it was okay.
Took it for a drive, but the engine light is still on. I noticed yesterday that while driving with Cruise on at 55 MPH when I came to a slight grade it dropped a gear, Tach went up to 2200 RPM.
Anyone have a suggestion as to what might be doing this, or does it need the scope read out?
Old Jan 6, 2013 | 11:26 PM
Cougar41's Avatar
Cougar41
Cycle the key from off to on (not start) three times within 5 seconds then read the codes off the odometer. There are over 100 faults that will make that light turn on.
Old Jan 7, 2013 | 08:37 AM
Ole Goat's Avatar
Ole Goat
Default 2006 Grand Caravan 3.8
Cougar 41
Thanks for the reply will try that and let you know the results.
Old Jan 7, 2013 | 05:14 PM
Ole Goat's Avatar
Ole Goat
Question Check Engine Light On
Cougar41
Thanks for your advice, just checked out your method Code P0406 came up on the odometer.
Old Jan 8, 2013 | 11:12 AM
b1lk1's Avatar
b1lk1
time for a new egr valve
