headlight adjustment 2009
Old Jan 8, 2013 | 11:52 AM
Don1960's Avatar
Don1960
Default headlight adjustment 2009
How do I adjust the headlights on my 2009 grand caravan??
Old Jan 8, 2013 | 03:18 PM
Tizzy1's Avatar
Tizzy1
NOTE:Due to the linear nature of the headlamp cutoff, a properly aimed low beam headlamp will project the top edge of the high intensity pattern on the alignment screen from the horizontal line to 53 millimeters (2.1 inches) below the horizontal line for domestic market vehicles, or to 100 millimeters (3.9 inches) below the horizontal line for export market vehicles. No horizontal (right/left) adjustment is required for this headlamp beam pattern in domestic market vehicles. Export market vehicles have a second horizontal (right/left) adjustment screw provided, which is accessible through a clearance hole on the inboard side of the front lamp unit cover. The high beam pattern will be correct when the low beams are properly aimed.
1.Turn the headlamps ON and select the LOW beams for vehicles in all markets except Japan. Vehicles for the Japanese market should have the headlamp HIGH beams selected.2.Use a screwdriver to rotate the headlamp vertical adjustment screw (2) on each front lamp to adjust the beam height as required.3.For export markets only, insert a screwdriver through the clearance hole in the front fender ledge to access and rotate the headlamp horizontal adjustment screw (1) on each front lamp to adjust the beam right or left as required
